Well another hour spent trying to get the rear wipers working today got them moving but not a complete revolution of the motor as the connecting rod or something is butting up against something which I can't make out what it is causing them to stop so decided going to get rid of the rear ones all together so has anyone used these to cover the holes up before or are they not the correct type http://www.t4srus.co.uk/vw-t4-wiper-arm-bung-wb1-38-p.asp
thats to cover the nuts on the wiper arms. so won't be right to fill the hole in the door you will need to find a gromit or get the holes welded and filled then paint the doors
Cheers thought they might be found some others on flea bay thanks again
