Folks,
The vehicle has done about 100k km and servicedonly by VW.
It has just started making a strange noise under the bonnet, probably in front of driver. Seems to happen only at low is speeds (max 60kph, generally less and at maybe 1500-1700 rpm) but when lightly decelerating or accelerating. It is low pitch. Sounds a little like a cross between a low pitched kazoo and a gently lowing cow! It last for maybe half a second so this makes it difficult to study. I FEEL it is when I have taken my foot of the accelerator, sometimes. So far, nothing seems repeatable.
Initially I thought it was my aftermarket air compressor kicking in but I isolated that as a possibility.
I have searched this and other forums - but no one has described their van as sounding like a cow!
Can anyone point me in a possible direction/test please?
Thanks in advance.
Sounds like the N75 vacuum valve otherwise known as the 'moo valve'. (serious) It is a common fault on earlier models like yours. The valve and attached pipe works fails causing a narrowing thus creating the moo noise. VW have upgraded a replacement part. If you do a search I am sure you will uncover lots more info. I'm having mine changed next week on a 2010 2.0. cheers
Thanks so much. I just had to laugh! Why didn't I search for MOO? Probably because I would have felt stupid! Looked on ebay and postage to Aus is a bit of a killer!
I'll do some homework tomorrow.
Thanks again for the bovine advice.
