1 - 13 of 13 Posts
Somebody stop me!
As the title suggests i have a sudden tappety noise from my ABL engine. The engine runs fine, pulls well and all vital signs are fine. As some of you will know its recently had a new head but i just cant figure out why this noise has suddenly started. I am going to give the van an oil change tomorrow but dont know what else to try, the only thing i did to it today was back off the fuelling a bit. Are oil pumps prone to failing? The noise only seems to appear when the engine is under load.
Any suggestions would be appreciated T:
Its about time I showed up
Not having much luck are ya mate.
I havent got a clue what would cause that! Not left ya tools under the bonet again have ya?! I:A:
Somebody stop me!
No mate, i am going to check the timing again tomorrow and probably will replace the crank pulley with new stretch bolts just to be sure and give her a service before i do anything. Failing that i will probably have to have the head off again and send it back to AW Engineering under warranty. The stupid thing is it runs and pulls fine and starts fine :confused:
Somebody stop me!
Discussion Starter · #8 ·
Too much fiddleing maybe?! You do like a fiddle dont ya?! I::D
I dont think thats the case bud, i just don't think the garage replaced that pulley correctly so i am doing it as a precaution more than anything else. The stretch bolt is going in with some loctite this time around me thinks. I don't want to risk using it without doing some investigations.
I feel for you mate. If anyone needs a bit of luck with ya van its you bud :ILU: Better to be safe than sorry.
As mentioned the vacuum pump can often be mistaken for tappets. Next time you hear it, pump the peddle and see if it goes.
Somebody stop me!
Discussion Starter · #12 ·
FIXED, and just in the nick of time too. The cam sprocket wasn't loose but had managed to shift so the timing was out. I can only think the tappet noise was pistons gently tapping the valves. Either way i have set it up TDC and re torqued everything and its back to its good old self again. T:
1 - 13 of 13 Posts
