I have just ordered two sunglasses holders, and was planning to put one where the passengers grab handle is, and the other on the drivers side But I don't have a grab handle, has anyone had any success with fixing through the headlining into the metal?
You can either put in 2 nutserts in there or just drop head lining drill 2 new fixing points & use selt tapping screws
Had a search for brackets and found some from banwy, thanks for the info, wasn't sure if there was a way round getting a bracket as it is only going to be a sunglasses holder
The metalwork is miles away from the headliner and it will pull the headliner out of place if you try to do it with long screws....we had a van in once and someone had used 3 inch screws...luckily they hadnt poked through to the outside:eek:. The bracket isnt that expensive and will hold everything in the right place.
