I purchased a 'surf key' for when I go trail running - an all too often wet and sweaty activity and didn't want to risk damaging the electronic key.
It wasn't cheap!
£78.60 to be exact - including postage as my 'local' VW Commercial dealership is 1.5 hours from home...
First time I used my lovely new key the alarm went off when I used it to open the van.
Tested it at home to see if I was being stupid in the dark but no... alarm goes off...
Just spoken to the service dept. at my 'local' dealer and they say that everything is fine and that is what should happen... ???
You can't start the vehicle without the electronic key...
So... why does the vehicle need to disturb everyone when you open it with the right key???
The dealer's answer was that surely you'd want the alarm to set and then go off when the door was opened, what if someone had had a key cut and then used it to open the vehicle...
What kind of logic is that??
Suspect I'll get similarly short shrift from VW Customer Services - as was the case with the stupid beeping alarm on the electric doors...
Ah well.
Here goes...
It wasn't cheap!
Ah well.
Here goes...
