Guys out of interest would the standard suspension from vw be workable for a full conversion, for argument sake the full works of conversion. Bed bike rack the lot
If upgraded suspension is required would the CMC Coilover set that we have selling on the forum be upto the task?
:ILU:
Why do you need to upgrade the suspension - it's a van designed to carry load. You might find that a T28 is borderline and a T32 would be better.
With the stock suspension do your sums and consider the weight of all the fitting and the all the parafanalia you will cart around and don't forget the passengers
Or are you looking at something else? Do you want to go lower?
Just seen your other post about your current van and you seem to have come to the weight conclusion yourself.
I would look for a T30 and that should be fine unless you ar hauling something different.
