Thanks to the handy diagram floating around on here I have found the dimensions for the interior length and width in mm.
If you guys could help me, I need the interior dimensions for:
SWB
From the headrest line to the sliding door aperture - ?mm
From the door aperture to the inner wheel well - ?mm
The length of the inner wheel well - ?mm
from the inner wheel well to the inner tailgate/door - ?mm
LWB
I do not yet own a van and I need these dimensions to help me decide how best to lay out my interior and weather I need to look for a SWB or a LWB :)
Thank you very much for your time and help,
Dan
HORACE
The difference between SWB and LWB is 40cm from the bottom of rear of the sliding door to the rear wheel arch. SWB are very common and LWB are a bit hard to find. mine a LWB as its what we had for sale at work. Check my build thread so far it may help you also check GAZ HOW. I used his as a bible to start with. T:
