Hi all.
I was wondering if anyone had any spare templates so i can ply and then carpet my van.....
Thanks in advance :ILU:
You don't need templates. Measure the distances top to bottom, left to right and you will find them fairly square. I thought templates would be useful, but the only bits that are tricky is cutting an accurate curve round the wheel arch. Since my wheel arches are in cupboards or under a RnR bed, the slight variations are not a problem and can't be seen. The slide door is the most noticeable & you can make a template with newspaper & masking tape in 10 minutes, though if you leave this till last, I guarantee you will be happy to do it freehand.
Good luck, Al.
