1 - 12 of 12 Posts
I have a pair of swivel seat and bases (currently fitted) the ones that dont make your seats any higher bought from a show last year from ade (i think) £140 ish if my memory serves me well
selling mainly due to the fact ive only used them about twice for their intended use
here goes i will need a pair of standard seat bases in return plus a bit of cash(£75 ish?) to fund a mudflap set or stainless tail pipe or front fogs or long nose bra you get the picture
so if you aint got bases for me pref grey then i cant let you have the swivels (i cant be :c looking for some need car everyday you see)
i welcome anyone with bases and a afore mensioned part or parts new or old for a straight swap rather than £££ as you may have guessed im a lazy get
i was going to drill a hole thru the swivel to padlock them in the rear facing position as a security measure lol ,but i didnt do it LOL:i thought i was a good idea tho !
if your ever up my way, ill swap you and £75 for them, but mine are both black and able to take Rover MG ZR seats..
Gaz..
standerd seats will fit back onto them straight away in the pre threaded holes, only have to remove (grind n polish) 2 pieces of angle steel i welded along base sides to accomadate the rover rails, so i didnt touch the old holes, just put rail on each side witrh new holes drilled and bolted through, easy removal , clean off, touch up paint , and i havnt modded the passenger seat as of yet,
hopefully someone else nearer to you is more willing to swap with you before you decide to start cleaning mine up, but it wouldnt take that long if your steady handed with a grinder, keep me posted,
Gaz..:ILU:
Discussion Starter #8
splitspat i lost your number ,had pm problems
These are still up for grabs dude
Discussion Starter #11
£8 quid through parcel2go.com they use dhl anything up to 25kgms
i need standards first tho from u so im not whitout wheelz*<:)>
1 - 12 of 12 Posts
