Hi all
Has any 1.9 T5 owner ever had a camshaft sensor fault / replacement??
If so can you share the engine symptoms with me??
Gaz
hi usually if a cam sensor fails ,the engine turns over a bit longer before firing , the ecu is looking for a reference point between both sensors cam and crank why do you suspect a fault ? cheersT:
You're bang on with that one pal
I disconnected last night and tried it.
I get rough idle on the first start of the day so just working towards a solution really
Thanks for the info
