Syncro prop shaft uni joint
734 views 0 replies 1 participant last post by  Oz Trakka
#1 ·
Hi am in the process of removing the VC from my 97 LWB 2.4 for a service. Have removed the prop shaft running from VC to the centre bearing.
The uni joint beside the centre bearing is quite stiff. I was wondering if you can take the end of it to clean it out & whack some new grease in it.
This is the one that has the rubber boot on it.
Have been thru All the syncro posts & U tube clips and don't seem to have anything on it.
Cheers.
192004
