Hi, just wondering if anyone could help or had had similar issues? When the van is not running all gears can be selected very easily. But when the engine is running and the van moving, 3rd gear is almost impossible to select. It goes into the gate, but doesn't 'drop in'. I have checked the position of the gear lever, and also the condition of the nylon ball on the remote on the gear selector, and all appears fine. Any help or guidance would be most appreciated.
Thanks!!
As above
Check the condition of the oil This can help to workout what's going on inside the gearbox
If contaminated as an interim measure you could flush and refill the gearbox This may help dislodge some of the gunk that builds up in your syncro Hope this helps
