Hi all, wonder if anyone can help...my 1.9TD (ABL) engine blew up with 'Turbo run'(?) last week. The engine is wrecked, so I am after some help with either engine replacement or engine conversion. I am able to do the replacement but would need to pay someone to do the conversion I think. I am in Cardiff area in South Wales. ANY help would be massively appreciated!!!!! Thanks in advance :)
Hi. I. Would go for a 1.9 tdi. From . A mk3 golf. You should look for a complete car you will need other parts from it
You could contact colse on here. He is in bristol
Good suck
rusty heap ('95 t4)
What's actually gone wrong - can you not just fit a replacement turbo?
+1A:
Watching T:
Rich.
If I am not mistaken (reading his post) because he means this:
https://m.youtube.com/watch?v=atW1XLAsOBs
and if he does mean that he had turbo runaway, I doubt there is much of an engine left to bolt a turbo to.
To the OP - sorry to hear of your troubles. As Huskyman says, quite a few have fitted the mk3 golf tdi engine, so a site search should turn up some info T:
rusty heap ('95 t4)
Agreed that a runaway can kill an engine BUT sometimes a replacement turbo (or even blanking the turbo's oil-feed to isolate wastage) & trying cheap oil in the motor is worth trying :*
What's a ball-bearing ( to seal turbo's feed pipe - nipple) & a £10 can of oil against the cost of instant replacement I:
Rich.
