Hi. Hope you can help. My T4 died on me.. managed to coast into layby. Tried to restart van. It started, but engine went straight to max power. So switched off. Tried again,same thing. Called AA and got home. I am thinking it's the pump jammed. As does the same with accelerator cable removed. Only adjusted fuel screw, for last part of journey. Any help would be great. Thanks
Discussion Starter #2
Still need your help guys. Also I have limited access, to off line stuff. Need your help to get back on the road. Thanks.
I have another pump, from a T4 but it is different. It have a black plastic box on one end. The wiring is different too. But both from T4 1.9td.
