It's sadly time to put my beloved T4 van on to the market. I've owned it for 13 odd years, but recently I have little time to use it these days.
I used to browse and use the forum a lot, but have lost touch the last few years, so no idea what I should be asking for it and was hoping you guys can help?
A lot has been done over the years and here are the main points:
- 1995 1.9D non-turbo
- Registered as a Motor Caravan to avoid London LEZ charges
- Audi TT seats on swivel bases
- Removable rear seats from a caravelle
- Caravelle alloy wheels (proper load rating)
- Side and rear tinted windows
- Extra speakers, including in tailgate.
- Rubber tiled floor and perspex fit-out for an easy clean / waterproof finish
- Resprayed dash, detachable steering wheel, pool ball gear stick
- Roofbars
- Electrical hookup
- Fiamma table leg insert
- Microwave and sink (sink still needs to be fully plumbed up)
- Rock and roll bed
- 195K on the clock
- Very little rust apart from hole by wheel arch shown in the photos. In fact when I was having a service at VW Connections in Cornwall 2 years ago, one of the cleaner vans he had seen recently.
- Paint work is probably the weakest point. A few scratches and bumps to be sorted. A purist would probably want a respray.
- Replacement door cards which came from a caravelle are a bit grubby
2011 VW T5.1 102bhp with tunit diesel tuning box increasing bhp to 120
SCA pop top fitted by Banwy
U shaped seating in the back which converts to a large double bed
Folding double passenger seat
Will come with either black VW sport line alloys or silver VW Thunder alloys depends on which I keep...
I have a VW transporter t4 which is in need of a bit of work done to it, which unfortunately I can't afford and unable to do myself, it has a pretty big oil leak, and the brakes need doing other then that drives really well I was just wonderingly how much it would be worth if I sold it
It is a...
Hi, I need advice.
In June this year my 2012 Caravelle's engine heat siezed and i had a new engine fitted at a VW dealership. I stated to them that I only had a DPF warning prior to the seize. To which they did a regen at a cost of £340.00 and did not offer/suggest to replace, after about 50...
Hi There
Tyre Tread very good, but obviously a budget tyre
Wheels in great nick apart from slight corrosion to centre cap area on one wheel.
4 x 18 inch wheel (not sure from what)
4 x HIFLY HB805235/50/18 101w xl
Trying to get a feel for what I could get selling on ebay or via forum
