Hello everyone, I started dismantling the T4 before it dawned upon me that it could possibly take more than one day to get the oil sump off, re-gasket it and put it back on. And here I sit on the end of my 3rd day, and wish in one way that I spent the money and let someone professional do this. I have a T4 2.4D AJA aluminium oil sump / pan.
I have found much help in:
post 146178 - 2.4 d sump removal
post 87489 - t4 sump removal
post 120754 - 2.4 T4 1994 sump removal
Some slight help from Haynes manual VW T4
I have learned the hard way that I should have:
A very very long 5mm allen / unbrako / hex with ball head - to remove hard to reach 5mm bolts on the sump
13mm offset ring spanner - to remove hard to reach 13mm bolt behind speed sensor
Maybe also 6mm allen / unbrako / hex with ball head - to reach the one up behind the speed sensor, but this may be a stripped 5mm, I am not sure
Besides that, a well equipped workshop and a lot of time or experience, of which I have neither.
An overview from aggie and some of my comments, on bolts:
3x 13mm headed bolts (two vertical easy to see and reach from below. one last is deep inside near speed sensor, a pain)
3x 6mm allen / unbrako / hex bolts (two horizontal in from gearbox, visible from left. one last is deep inside near speed sensor, a pain)
Many 5mm, some are easy to reach. One needs dismantling of left drive shaft to get to. Two are placed within flywheel so you need to crank the engine till they are visible, and use preferably the very very long 5mm with ball head.
I would also recommend looking at the gasket image to help identify what bolts you are missing, but it is not the full picture. There are more bolts, but in other directions. Google Image search for oil sump gasket
Since mine was done with a gasket before, I had to leverage it out and pry it open, and probably damaged it a bit in the process, before I realised - it was still stuck up in one corner. After painful fiddling, I got out the 13mm bolt behind the speed sensor. Thought I was in the clear, only to realise yet another 6mm allen / unbrako / hex bolt was located very close to the 13mm bolt.
It is so tight in there, and I realise I need to hit the 6mm tool to get inside the bolt, I think it is partially stripped, or in other ways, full of dirt. Does anyone have suggestions here? No natural space for any tools to hit. The only solution I can come to think of, is maybe 70 cm long allen / unbrako / hex bolt with a ball head - but I have no idea if I can get enough torque on that to break it.
I still have no idea how I will be able to get all the bolts back on, but I guess it is easier, that part.
In advance, thanks for your help.
