Hello everyone,
I am sorry for my first post to be asking for help but I am really in the sticky stuff and need some assistance.
I have wanted a T4 for ages and recently my wife had to take a job in Essex (we are in Poole) so I used this as an excuse to justify buying one as I would need a vehicle big enough to get the Kids, dog and luggage in so we could go visit.
I found what appeared to be a sound 2003 2.5tdi ACV lwb. Not too much rust, started well, twin slider, the interior was a bit tired but still useable. I bought it and have had it now for about 6 weeks, but the last three weeks it has had major problems starting. Sometimes it would start fine, then next time it would just click as though the started motor was faulty, then next try it would start, then it would be completely dead and I would have to jump start it.
I tested the battery which was knackered so fitted a new one. I removed the starter motor and tested it, it was knackered, so bought and fitted a new one. I have checked the charging which is at about 14.4v when running. The battery is holding its charge over night. All was fine for a few days but now it has completely died. I have also changed the ignition switch in case that was the fault, and have checked and cleaned all the earth contact points in the engine bay.
Now when I try to start it the engine isn’t turning, relay 103 clicks constantly, and there is a clicking coming from the front of the engine but I can’t locate exactly where. The voltage in the battery drops to almost zero when I turn the ignition to start, and when in position 1 is causing the battery to fall to approx 5v. The central locking, windows and electric mirrors struggle to work. When I remove the key the battery slowly regains its charge and then sits at approx 12.6v.
When I put a jump pack on it starts fine. Once started it runs fine, and all the electrics work, but once I turn the ignition off the same problems detailed above start again.
I have looked through all the relevant threads for advice and as I said above have checked/changed the battery, starter motor, alternator, earth points, changed the ignition. I have also tried putting a new earth in place but it made no difference. I also read that there can be faults caused by damage to the wiring in the door bellows. I checked these and found that the driver side was in a terrible state and a really poor attempt at repairing it had been done. I have now removed this section from the loom completely to see if that helped. It didn’t. (Can someone please let me know if having it removed could also prevent the bus from starting).
I have also read that there can be a problem with a black and white cable running from the back of a relay to the ecu but can’t find the thread so if anyone can shed light on this it would be great fully accepted.
I am now out of ideas and would really like any help or suggestions that you guys can give me. I really need to get this starting properly.
Thank you
Thank you
