Hello
I have a 1993 Eurovan 2.5L petrol,(AAF engine)manual transmission with a cracked exhaust manifold. Does anyone know if the 2.5L petrol ACU engine exhaust manifold will fit my engine. I do know that they both share the same exhaust manifold gasket. Thing is I'm not so sure about the cylinder spacing. I do know that I will also need a different down pipe as the ACU engine manifold is a dual outlet.
Did you get any kind of resolution?
The flexible coupling between two parts of my manifold has gone and I am being told I need a new manifold I have 1992 2.5L petrol
I did use the 2.5L petrol ACU engine exhaust manifold... and had to buy the corresponding dual outlet down pipe... worked perfect... like an upgrade. I will tell you its a real pain in the ass to remove and replace that manifold!
