I recently bought a T4 from 94, and it has a idle problem.
When I start it, it goes for a few seconds then it dies. Otherwise it´s running perfectly as long as I give it some gas.
I changed the idle-regulator but no change, I also changed the airfilter but no change...
What could it be?
Looking forward for some help or redirection to threads with a solution ;)
Calle
There is a couple of relays you couls check, relay 30 and I think 109 (bottom right one) its fuel pump. Hold your hand on them when starting your engine, if theyre good you should feel them click.
