Hello all
Im new to the forum so bare with me if my questions seem a bit silly. But anyway my van indeed died during acceleration i had about 70km/h speed and went on to switch for the fifth gear and car just died.
I had driven car for about 5-6kms and engine was quite warm as my friend had just borroved the van before.
There was also the insidence previous week when i ran out of diesel as i forgot to refuel the van in a hurry.
When i ran out of the fuel i did fill 18liters of diesel and she started right up without any problems(i had to crank the van three four times but anyway).
When the van died i had about 1/4tank of diesel in it, and i have since filled another 18liters on it just in case.
But back to the current situation so currently the car:
-cranks nicely.
-glow plug light comes on for a few seconds when try to start in the morning.
-no fault codes with vag-com eng/immo.
-no fuel to the injectors.
-new fuel filter+that plastic connector that goes on top fitted and feed pipe blown with compressed air.
-tried to feed shutoff solenoid straight from battery no help.
-Injection pump timing belt felt really loose and timing might be off will check tomorrow
But does that explain no fuel to injectors, does ecu cut off the fuel if the timing is off and wouldn't it trigger a fault code?
Any help would be greatly appreciated. If someone would have wiring for the ecu and injection pump that would be great, i would like check the wiring harness.
-cranks nicely.
