looking to buy and looking at tdi ( blue I) as above on sat with 133k.
Reasonably mecahnical and looking for a few pointers as to what to watch for.
This ons has had belts and water pump changed 4k ago
T:
As a matter of interest what is the Blue I mean apart from blue lights in the dash board?
Cheers all...
PS: anyone interested in an S2 avant ... 365bhp gotta go?
blue i is 88 bhp a 1/4 of what your s2 has H:,just the obvious to look for belts which have been done and saves you the trouble,regularly serviced,check gearbox for noise or jumping out of gear
Pedal box guru
T:
Cheers all...
The blue I means it is a 88 BHP not the colour of the dash lights.
Take a look at the pedalbox, if it has any movement in the master cylinder, then it will need replacing sooner rather than later.
If it sounds tappety at tick over, press the brake pedal several times, if the ticking stops, then the vacuum pump will need replacing.
Other than that, just enjoy it.
Cheers Trev.
