just thought i would ask does anybody know how much oil goes into a 2ltr petrol 1993 t4 and what grade to go for as im due a oil filter change the van has 88k on clock if any use thanks
l use 10w-40 semi-synthetic, 5ltrs including filter, 4.5tlrs without filter.
I did a double oil/filter change over christmas, just to clear out engine rather than use engine flush. Cost £38
When filling up with new oil, check on dip stick as you may find it will not need reccommended amount, prevent over filling.
Go for a good brand of oil and filter, makes a big diffrence with performance, use VW stuff from TPS or Fuches oil, GSF is good for service parts. Nearest ones to you are Cardiff.
Worth doing air filter as well, only 5 min job.
