Hi, 2003 T4 auto, Gearbox itself OK. Changes as it should when left alone.
However, on going down a steep incline the other day, I found I could not knock it back into 3rd gear to help with the braking.
It was just locked out. After negotiating the hill using footbrake only, I pulled over and found that with a lot of effort I could engage
the lower gears. I am guessing that it must be a method of adjusting the selection levers or could it be an errant solenoid.
Any suggestions gratefully accepted.
Frank
