I hope I explain this right so here goes, I am trying to locate a part off the distributor, after having trouble with the 2.5 Petrol I pulled the distributor out and at the base of the unit there is a plastic circular piece approx 50mm across with a plastic lug which obviously drives off the cam, there is a roll pin going through it and the main shaft.
This plastic piece has a crack in it and I would like to replace it, does anybody know where I could get a new or second hand one so I can replace it?
Thanks in advance.
Thanks in advance.
