Here is the brand new double seat swivel base designed by the Customshop team (Community Registered Design 001382212-0001). We have been manufacturing and supplying VW camper components to the trade and public for over 10 years now. The VW T4 transporter camper van double seat swivel base is the most compact seat base on the market with all 4 locking points hidden away, it has a more streamlined and barely visible look from the outside (raises the seat by 38mm). The locking points work on a unique 1/4 turn 'quick release' system so removing all 4 fixing bolts and rotating the base takes literally seconds! They are manufactured in the UK and made from 4mm laser cut steel, and has passed seat belt anchorage safety tests using a pull test on a specialist test rig to EC Directive 76/115/EEC as amended by 2005/41/EEC. The base allows you to rotate the double seat 180 degrees and completely transform the living space of your camper. Fits all T4 models (without anchorage point seat bracings) and fixes directly to the existing floor mounts so no drilling required, installation takes approximately 30mins from start to completion. Comes with step by step fitting instructions. T:
www.facebook.com/customshopdesigns
http://www.ebay.co.uk/itm/2910126034...84.m1555.l2649
