Hi all, I have a 1996 Compas motor home based on a t4, with the 2.5 5 cylinder engine. I think I have a problem with the engine fans not coming on as the temperature gauge gets very close to the red zone esp on sunny days and I never hear the fans coming on.
things I have checked so far are the two 50 amp fuses behind the right side headlight, checked the voltage both side of that all ok. When I take the plug off the temperature switch on the radiator there is no voltage on any of the terminals and I’m sure I have seen on here that there should be voltage there.
any advice on what I can check next? I’m wondering if there could be an issue with the control unit?
any advise gratefully received.
