Help! Spent a couple hours today following the how to guide which was great. Replaced switch with double pull, relay & wire into A2. Come to test time, front fogs come on with ignition like drl's, switch does nothing. If i pull the relay lights remain on. It's like they just have a permanent live feed.
Any ideas please where to start??
Discussion Starter #2
Well, what a div... I have put the pin into pin 1, not 8, assumed it worked downwards in numerical order ? Can't pull block out to try release it so now need a new crimp connector so can cut wire, fit new connector & slot into correct pin 8. Anyone know the size crimp size part number though? 000979****
