Hi, im about to purchase a 98 t4 2.5 petrol caravelle which seems to run fine except it has a whining when in gear. From other threads im guessing prob some bearing issue. As a back up I also own a 97 t4 2.5 petrol and was wandering if the gearboxes were compatible if the caravelle is f**kd and it needs a new box. Any reccomendations would be welcome..
Full of Cr*p....
You'll have to check numbers...97/98 was a difficult time....(Especially for diesels....don't know about petrols....)
98 reg, may be a 97 build....or the '97 may have been an early release.....months/weeks can make a difference.
I have a 2000 registered van....but according to the VIN, it wasn't built until Jan 2001.
Maybe it was "ordered" in 2000?!?!?!?
VIN search should show you what gearbox number was fitted....
To be honest, I wouldn't touch a petrol with "someone else's barge-pole"......I don't have enough money to fuel one!
Thanks for the info. Ill do a vin check. I know 97 was a changeover year. Have had my 97 petrol for 3 yrs with hardly any probs.
Ok so the caravelle is a 12/97 build but compliance is 03/98.
And the transporter is 10/96 build compliance 1/97 .
Anyone know if the gearboxes would be compatible? Both 2.5 petrol
one main diference in those ages of gearbox is the rear / lower mount position, earlier ~'96 had a gearbox mount off the rear of the diff case whereas ~'96onwards had the 'pendulum' mount (from below / centre of the gearbox that connects to the crossmember below the rack)
allegedly, these will swap between vans:*
examples of the mounts..
the 'earlier' or pre '96 type that bolts to the rear of the diff case.
the 'later' or post '96 type, commonly called the 'pendulum' mount as it bolts to the lower / middle of the gearcase then connects to the crossmember (same position as earlier).
to confuse matters, the very early t4's had a diferent rear mount
BUT this shouldn't be on a van of the age you refer to (also, takes a diferent suspension crossmember and possibly gearcase to fit:* )
mounts aside, theres about a hundred diferent gearbox ratio codes, the code is stamped on a machined surface between the bellhousing, startermotor & gearchange turret (on '02B' gearboxes), theres a code comparison list https://www.vwt4forum.co.uk/showthread.php?t=90788
sorta something like that anywayI:
Rich. )probably written the above ~20 times on this forumI: )
Thanks for the info. I did have a look through the forums first but couldnt find an answer maybe add a better search function (rich!!) No need for the put down. Appreciate the help its a great forum without the smart remarks
actually, was remarking that its out there BUT I couldnt find itLOL:LOL:LOL:LOL:LOL:LOL:
^^ I'm not reading through all my old posts so I just re-wrote itT:
as to the forum's search, its ****.I:
better to google search for the problem BUT add vwt4forum in the search & it'll trawl the threads here:cool:
Rich.
