Hi
Im wanting a pair of heated windscreen washer jets for a 2003 t4 short nose. Cheers NigeT:
what year is your t4? they're normally standard-fit on post '96 vans, look at thedrivers bonnet hinge, you'll see a black rubber pipe (screenwash) and if the jets are fitted there'll be a black plastic tube containing a pairof wires for the heating elementI'm after a pair myself
Hi rich my t4 is a 03 plate with the wire and tube for screen washwhat year is your t4? they're normally standard-fit on post '96 vans, look at thedrivers bonnet hinge, you'll see a black rubber pipe (screenwash) and if the jets are fitted there'll be a black plastic tube containing a pairof wires for the heating element
also an option on earlier vans....
late mk2 golf, mk3 golf, B3 & B4 Passat all have these heated screenwash jets
where are you located? I've a few sets with loom if you need?
Rich.
