Is it possible to put a inner bell housing of a 2.4 D syncro box onto a 2.5 tdi Box (EWB) , Box code for 2.4 syncro will be supplied soon
Inner Bell Housing is the part of the Gearbox that attaches to the Block , which can be un bolted from the main body of the Gearbox
Purpose is to achieve better( Diesel) gear ratio from the EWB ratio in a Syncro Box CTV , I'm trying to find out if the inner piece of a syncro box will match with a 2 wheel drive Box
Aha, & what would then the outer bell housing be?
I suppose U ask abt a straight bolt on job??
What vehicle is this going into anyway?? Have U looked at the overall ratios?
I have trouble following U:*
93 T4 ,,, inner Bell housing from CTV syncro w/ differential / transfer case ,,,, bolting to a center part / main body of the EWB Gearbox ,,,, EWB are the most desirable ratio for 4 and 5 inline motors
The gear ratios in the ewb box aren't that different to the other boxes it's the higher ratio crown and pinion that is the main difference. It would be easier to remove the gears from a Golf tdi gear box and fit them in the van box and that would give you a better spread of ratios than are available in the van.
