We have been asked for these over and over, so our product team set out to make one!
And it's done!
This cable is a one piece unit apposed to the original two piece unit that Volkswagen originally supplied, and comes complete with exhaust heat sheilding.
Fitting guide.
To remove the old cable it is not necessary to remove the instrument cluster as access can be gained by lowering the fuse box cover lid, allowing you to reach up behind the cluster and unclip the cable. When this is done you can pull it though the bulkhead and unscrew the other end from the gearbox drive pinion.
When refitting ensure the cable is routed correctly with no sharp turns or kinks.
Pick one up online here!
http://www.vwheritage.com/vw_spares_Speedo-Cable-1900mm-RHD-T4-09-90-12-95-702957803_act_shop.product_pID_159394866_lang_EN_country_GB.htm?crumbStartPage=1&crumbStartRow=1
Andy
Id just like to say I bought one a couple of weeks ago from you and installed it last weekend. Works a treat! Cheers!
Ooo good work, I spent ages looking for one of these and ended up bodging one out of a universal kit. Glad someone is making / supplying these now
