1 - 20 of 253 Posts
T4 Twin Battery Trays
Similar to alot of others out there, Allows you to fit 2 batterys where your battery normally fits behind the headlight
This one holds 2 batterys that are 175mm Wide, Includes Clamp and Screw, the front lip is turned down instead of up so any length (that will fit in the space)
They are made from Mild Steel and Eletroplated.
Price is £30 + £5 P&P (delivered direct via collect+, if you want send to your local shop let me know)
I Keep these in stock now so delivery will be between 3-5 working days. Unless i'm on holiday!
PM me for paypal address.
I've got a couple photos
(stainless one was my Prototype)
Discussion Starter #8 (Edited)
Discussion Starter #12
hi daniel my standard battary is 354mm x175x190 will this still fit ,as i dont want to have to shell out again for a new one .its only a year old
just had a look and see that 2.5tdis can be fitted with a 354 long battery,
Solution here is i'll bend the front lip down instead of up and you'll be able to fit any length battery (as long as you can fit it in)
As long as the battery's 175mm wide
Hi BMAN,
Do you still have these please?
My battery is 175mm wide and 350mm long so would need the lip MOD if ok?
Thanks.
1 - 20 of 253 Posts
