60 plate 2011 registered
£19995 no vat. For pictures see eBay item number 131923602437
It has been converted from a van in great condition, front seats are in excellent condition (previously had seat covers) front carpet is clean and it's had a full respray externally, all glass and fittings were removed for this so there is no overspray etc.
Registered with the DVLA as a Motorhome.
The inside is fitted out to a very high standard, the pictures don't do this justice -
- Smartbed - in fabric to match the front seats
- Waeco CR50 fridge - 12v / 240v
- SMEV 9222 sink / hob unit. - gas bottle in rear cupboard, electric water pump
- Passenger seat swivels around
- Full CBE electrics including fuseboard/breakers 240 and 12v outlets and Leisure battery charged from vehicle and 240v
- LED mounted roof lights and floor entry light , front cab lights also converted to LED
- Clip on table to convert the cabin for dining
in terms of the vehicle spec it has the following -
- Climatic Air Conditioning
- Genuine multifunctionsteering wheel
- Instrument upgrade so the dashboard displays MPG, distance, fuel miles remaining etc, accessed via steering wheel buttons
- Flat tyre monitoring system
- Lowered suspension springs - H&R
- Pendle Performance tune and DPF delete
- Upgraded 2 way MB Quart speakers
- Roof mounted aerial (genuine VW) with cables run for FM, DAB, NAV and Phone
- Front fog lights
- Genuine VW Caravelle headlight units
- Genuine VW Caravelle high gloss front grill
- Factory fitted rear reverse sensors
- Factory fitted cruise control
- Genuine black sportline alloy wheels with nearly new tyres
- Black sportline mirror caps
- Carpeted front cab - not vinyl floor
In terms of mechanics, a lot has been carried out , all within the last 5000 miles, and full documentation available -
- Replacement genuine new base VW engine
- Reconditioned cylinder head
- Replacement of turbo chargers - invoices available for turbo and fitting - turbos still under warranty
- Replacement of both clutches, DSG mechatronic and gearbox recondition - invoices available and under warranty for 5 more months
- Engine Oil/filter change
- Fuel filter change
- Genuine VW front discs and pads fitted
- New water pump
- cam belt changed - genuine VW parts / kit
- Air conditioning compressor replaced
- all 4 tyres replaced
- Haldex 4motion oil change
- new Genuine rear shock absorbers fitted
MOT expires in January, paintwork as you can see in pictures is unmarked, no chips. Recorded miles are 210k.
Vehicle located in Salisbury Wiltshire.
