Went to do my transmission oil change t5 2008 managed to loosen the drain plug but did not drain the oil until i could open the fill plug, used a 17mm hex but felt a little loose when inserted into the fill plug, is this the correct size to use
applied a little eat around the plug but just could not budge it as its an awkward position and cant really grip the allen key
Whats the best tool to use for best access and grip, a allen key or socket hex type on a wrench
