Hi any wise sages... On Cam Position issues.
Delayed cranking problem..
Have fitted a new GPS but no change.
On checking the connector pins I have :
Pin 1: 4.8v (should this be 12v?)
Pin 2: 4.9v (which I ssume is correct)
Pin 3: 0v (0.7ohms continuity so is Earth)
I've attached wiring diagram but doesn't confirm In is 12v, but I suspect it should be, but I can't ID it's source to check continuity back to pin 1 (ref: T6/q1 Black/Green wire.) .. But where is T6 plug?
Any help appreciated.
James.
James.
