Can anyone tell me if it is possible to seperate and remove the part of the door card that is highlighted in green in the photo from the rest of the door card as I wish to dip this part in hydrographic film to give it a wood effect?
yeah i believe you use a soldering iron to melt the clips pop it off, do what ever you want to do then put it back together with glue and if possible remelt the clips. I took one apart to do this but in all honesty just go to TPS and buy a new one save your self a whole heap of pain if its just because its damaged. If you want to cover it then be careful of the extra material around the edges, it will be even harder to put back together.
