One of the last jobs left on my 2015 ex-AA T5.1 conversion is to sort out the tow bar electrics.
The van came with the tow socket already fitted (standard 7 pin) and a LED CFC module fitted inside the bench seat.
Most of the the AA electrics have been removed but I just presumed that the tow bar set up would work. Why would they disconnect it I thought?
Well something is amiss as the socket appears dead, tried my Thule bike rack and a tow bar tester, nothing...
I have tried to look for lights on the LED module as per the instruction sheet I managed to find on the net, again nothing.
Re plugged everything in and out etc. Fuses under the bench seat all seem OK
I have tried to get an Auto electrician booked for months in South Manchester but he keeps fobbing me off.
Problem is, I can't use either my bike rack or fit my swivel bench seat base until this is sorted.
Don't know if this is of use but when I got the van it had a couple of codes including this one that perhaps sounds relevant:
CAN NETWORK GATEWAY 01517 "Control Module for trailer towing sensor J345". Maybe just needs re-activating in VAG?
Here are some images in case anyone else has come across this maybe with the same module or an ex-AA van?
Any help or advice much appreciated!!
(Or a recommendation for a decent Auto Sparky in Greater Manchester / North Cheshire / High Peak? or even someone ex - AA !!
