ScoobyscoopNew Member
Hi
Frustrating problem with a T5.1 Heater,
Blower works fine on All speeds however
Hot cold dial delivers very hot air when turned fully anti clockwise but cold on every other position even if turned back just a smidge
Any ideas ?
TIA
Sounds like the actuator flap motor is probably stuck. If you have access to VCDS you can scan it for faults.
I dont have access to VCDS
Is this something that is easily accessed & unstuck or is it a new part required generally
Hello there. It’s appears that we are also facing the same problem, only noticed today. We have ac in ours, not sure about you.
But when set at 22c it’s fresh, if I move it closer to the max 26c it gets warmer for a second then it’s cooler again. The only way is to have it around the max 26c to have some heat. All speed settings are working. Very odd.
I’m lucky that I have vcds and will run it tomorrow. If I get any errors I will share it.
