Hi folks
I wonder if anyone can help me I have a t5.1 2010 130. The wipers have stopped working, but the washers still work . Reading through the forums it seems the most likely cause is the bonnet switch, all I can find is a switch from just campers which says it fits the 2003 -2010 models. I was wondering if the same bonnet switch is fitted to the later models? Or fitted to anything else in the vw/audi range? ? Here's hoping that the guru's can help lol
The bonnet switch will normally only affect the intermittent wiper setting, you need to get someone that knows what they are doing to plug in and check live data, this will check the switch is working, check bonnet switch operation, if this doesn't highlight an issue then it will come down to wiring diagram and manual checking from control unit to motor.
