After having a new turbo fitted and the proper oil in our van now the cam is as noisey as hell and going in to limp mode even at 40
its in having a new cam this week is there anything else they need to look for while its being done
any help anyone
after all the work im hoping to have a NEW VAN its a AXD engine
The 'proper' oil in my van always makes it sound like a bag of nails... (2007 2.5 BNZ). Tha's why I run Quantum Synta 10W40. Quiet as my old T4 now!
That's an awful lot of work and expense because of a 'noisy' cam.
Check out the vacuum connections to the turbo - it could be a sensor problem or a control issue.
You need to get it on VCDS to check the fault codes as to why it's dropping into limp mode - that should point you in the right direction.
Hope this helps....
power failure on diagnostic plug so im in the hands of a garage we have been told to use only the oil spec from VW as cam wear caused by wrong oil on the 2.5 engine
