Hi All,
I am seeking the advice of you guys for a fault with my T5 2.5 AXD engine on a 2005 plate (198k on clock)
First of ;
Coolant mixed with the engine oil - water entered the engine. After reading the symptoms online and given advice it pointed to either;
Water-Pump, Head Gasket.
I decided to go with the two and replaced them both, whilst down there I replaced the the oil cooler and all relevant head bolts,gaskets, glow plugs etc etc and used all the special tools required for locking the crank and setting up the timing.
(turned out too be more the water pump as the bolts had came loose that was securing the unit in place, and the seal was chewed up...so if I could give any advice, start there)
I inspected the turbo whilst the engine was in bits and the turbine blades had some play in them, so decided too change that also as a precaution.
So after I put it all back together with all parts meticulously being serviced and cleaned - it struck up first time and all seemed fine however was bellowing out plumes of white smoke, which I thought would of been excessive oil burning off so decided to take her on a run which after 10 miles the smoke cleared up, but as soon as she was turned off and then struck up again, the clouds of smoke appeared again straight away....
Was advised that the turbo seals in the rec turbo may be at fault so they gentlemen who I purchased it off sent a replacement - put new one again and still the same problem.
Ran it through a diagnostic machines and fault came up 'cylinder 4 misfire' decided to run a compression test and cyclinder 4 was down on compression.
Checked the wiring loom for resistance and continuity - all within the specification.
Replaced injector number 4 with a recon unit......STILL THE SAME PROBLEM
Hit a stumbling block now - engines been stripped that many times I could do it blind fold.
The smoke is of white nature, that does sting the eyes so my understanding is that it is un-burnt diesel fuel in cylinder 4.
Daren't start her up anymore in-case it does anymore damage....
Any help will be greatly appreciated.
Possibilities. . . ?
Warped head around number 4 cylinder? HOWEVER I HAVE NO WATER LOSS ANYMORE.
Cracked head/Injector bore on cylinder 4 ? DID CHECK FOR ANY CRACKS WHEN REPLACED H/GASKET AND LOOKED INSIDE THE INJECTOR BORE WHEN REPLACED LOOKED NEW WITH NO INTERNAL WEAR.
ECU - keeping injector 4 constantly spitting out diesel?
Piston rings/Piston damage ? CHECK ALL THESE AND POURED DIESEL IN THE PORTS WHILST OFF TO SEE IF THESE HELD THE FLUID AND ALL HELD THE DIESEL FOR A LONG TIME, WHICH INDICATED A GOOD SEAL.
Bent con-rod ?- AFTER TURNING THE CRANK AND SEEING ALL PISTON LINE UP TO THE CYLINDER BLOCK COULD NOT SEE ANY DISCREPANCIES IN THE LINE UP OF THE PISTONS ETC.
Timing out ? HARD TO BELIEVE THIS AS ALL TOOLS WHERE SET IN THERE POSITION AND ALL OTHER CYLINDERS ETC ARE COMING BACK WITH GOOD COMPRESSION AND STARTS ON THE TURN.
Injector Wiring Loom - AGAIN CHECKED ALL WIRES FOR CONTINUITY AND RESISTANCE ALL THE SAME WITH NO READINGS ERRATIC
Any suggestions before I am told I need a new engine from a dealership/garage?
Appreciate your response.
First of ;
