Evening all,
Need to pick your brains about an issue I have with my van. Its a 2.5 2009 T5 with 135k on the clock.
Its just had a new clutch and flywheel done by a local garage. Since the new clutch and flywheel was fitted, I am now getting vibration under full load when the engine speed is between 1500 and 2000rpm. If the engine speed is in this range and you floor it, just after the turbo spools up (so full torque is being output) the whole van vibrates like you're driving over a cattle grid.
My gut instinct was a dodgy flywheel being fitted, so took it back to the garage. They had a look and diagnosed play in the off side drive shaft. So, I replaced it, took it for a test drive, same issue! So I crawled underneath and noticed a bit of play in the near side drive shaft, so I changed that, took it for a drive and still the vibration prevailed! So I'm now £650 down for the clutch and flywheel (although this needed doing anyway due to clutch slip) and £100 for a pair of J&R shafts.
Anyway, took it back to the garage again who have had it for 3 weeks until today when I picked it up. They also then diagnosed it as a faulty flywheel and raised a claim with Euro car parts where they got it from. Eventually, Euro sent out their "specialist" to sign off the claim, and he declined it saying its actually play in the gearbox output bearing..... Garage have quoted me £700 for replacement!! So thats where I am now....
Has anybody else had similar problems to this?
I am very sceptical of it being the bearings because I had no such noise/vibration at all before the clutch and flywheel was done. It just seems too coincidental to me and I can't afford to throw £700 at it without first being convinced that the diagnosis is correct...
Cheers all in advance for any response
