Hello! Thought I'd share my experience of my recent breakdown as I'm still flabbergasted that a water pump failure can result in needing a new engine or at least a very expensive strip down and repair.
After driving my T5 2.5 Diesel (AXD engine) for 60,000 trouble free miles I recently broke down on the M62 (with 166,000 miles on the clock) after a slight judder followed by a flashing, beeping oil indicator light. I staggered on for about a mile (mistake!) as I was very close to service station and wanted to get off the motorway if possible.
After just making it into the service station car park before the engine gave out I quickly established there was no coolant left and added some water to establish if there was a leak - the water disappeared and after a quick internet search I discovered that a faulty water pump might be the cause whereby a faulty unit can allow coolant to flow directly into the engine sump.
Unfortunately, it seems that the mile or so over which I drove the van to get to the service station allowed water to get into the engine. The water caused a hydraulic lock as the pistons tried to compress it and the resulting pressure bent the con rods (at least).
My advice to anyone owning a van with this type of engine (R5 engine with camshaft and ancillaries driven directly by gears) is as follows:
1. If you notice any leaks which could be oil, water or a mixture of oil and water, check if the leak is coming from the water pump. If it is do not drive the van until you get the water pump replaced. I believe there are 2 seals in the pump, one engine side and one coolant side, when either is faulty a hole in a void in between the seals will allow the fluid to leak out (so revealing that the water pump seals are failing).
I had noticed a leak over the previous couple of weeks but failed to make the connection to the water pump.
2. If your van has done a lot of miles replace the water pump. Should I ever get my van on the road again I will replace the water pump after the next 80K miles.
3. If you get a sudden problem where the oil indicator light starts flashing stop the van immediately it might save you a fortune.
As things stand it looks like my best option is a scrap / re manufactured engine. I've had mixed advice regarding re-manufactured engines in particular for this type of engine, as the aluminium block prevents re-boring the cylinder bores without using liners (the aluminium alloy bores are plasma treated not lined) ...and it's apparently tricky to remove and replace the cylinder head and maintain original camshaft gear clearances?!
Any feedback on any of the above will be much appreciated, in particular if anyone feels they can recommend a re-manufactured engine supplier please let me know. I'm looking at Engines.OD.com but no idea who actually supplies this company with re-manufactured engines.
Finally, I wrote to VW asking if it might be prudent to include a specific note in service schedules to check for leaking water pump and due the the very severe consequences of failure even consider making the water pump a serviceable item. They tell me they have passed this request onto their technical team. I won't hold my breath whilst waiting for an answer
