May be a stupid question but !!!
Do you need a diagnostic machine to plug into the vehicle to work the ABS pump to perform a brake bleed on a 2006 plate 1.9tdi T5
Get yourself one of these. Just uses a tyre for pressure
2006 T5 T30
I second this recommendation!
I had the rear calipers and brake lines off my T5 (also a 2006 1.9) so the lines and ABS pump were totally empty when I came to bleed them, I used the Gunsons Eezibleed and you can do the whole thing on your own, no need to even pump the pedal.
