1 - 11 of 11 Posts
Hi all,
My T5 captains chair left hand arm rest has broken. :( It has no resistance to sit square so just flopps down. A pal of mine has taken it of and says there is a small lug of cast inside the arm, this he belives belonged to the shaft which the arms sits on. Does any one know if you can gat a replacement part for this...T:
You can't replace the broken bit, you have to buy complete arm from VW, around £100 each... Had to replace one on mine :(
Does anyone know the size of the torx screw bolt in the t5 armrest to take the unit off :confused:?
The fixing isn't a torx... it's a Spline Drive M10, similar looking, but not compatible with a torx bit.
this was common on the t4, and now there is a fix so im hoping if we wait a bit longer soneone will design and build a fix for the t5
1 - 11 of 11 Posts
