1 - 15 of 15 Posts
Hi all.
Having some issues with my drivers door lock.
It has always been a bit temperamental, sometimes not locking or unlocking with the rest of the doors.
Unfortunately, as of yesterday, it won't open at all.
I don't have a key for the door locks as the previous owner must have had them replaced but only ever used the fob, so I am stuck with a door that doesn't open.
The door lock doesn't make a noise or even attempt to unlock, it's completely dead.
Any idea what it could be?
Thanks in advance
Also, can anyone offer any advice on how to open the drivers door? Thanks
Theres a few videos on YouTube showing you how to open doors and repair/replace actuators 👍🏻
Ye I found most of those, thanks. Unfortunately, none of them show you how to open the door
Sounds brutal but give the door a big whack from the outside. Wind window down and do the same. Keep whacking and clicking the key fob button.
Try this one 👍🏻
I've tried all of the above, still no joy.
I have managed to remove the inside door panel, does anyone know how I now open the door?
I need to override the lock some how.
Does that hooking thing he does in the video not work? I’ve not tried it personally tbf (🤞🏻)
Hit the door firmly when the door lock is and keep pressing the unlock button. 9/10 it will unlock.
Replace the door lock. The its something to do with the soldering on the locks circuit board that go weak.
Discussion Starter #12
I can't remove the plastic bit to get the wire in to the door unfortunately
Will give it another go, thanks. This use to work, but I think it has now completely packed up
Discussion Starter #13
Nope, still won't open. Tried to open it by making a small hole in the lock enclosure and turning some cogs but nothing...
I guess the last resort is removing the lock with a crowbar???
1 - 15 of 15 Posts
