My 56 plate T5 windows have stopped working both passenger and driver side, the strange thing is that if i disconnect the switches and the motor plugs then reconnect them they all fully work again for a time, the other issue is that the driver side switch will not operate the passenger side window at all.
I've confirmed all the under seat wiring and have found no faults.
I've swapped motors over and both will again work, i.e. drivers motor will cycle when connected to passenger switch as will passenger motor when connected to driver side switch.
Any ideas where to go next with this.
Anybody know the wire colour codes to function on the multi pin plugs (there is a lot of wires to make a window go up and down !!!!!):unsure:😤
