Hi, Can any one confirm if this is a fault with the Crack Sensor or an wiring fault.
Chassis Type: 7H (7H - VW Transporter/Multivan (2003 > 2010))
Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56
57 6E 76 77 78 7D
VIN: WV1ZZZ7HZ9H034508 Mileage: 378660km-235288miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 038 906 016 AJ HW: 038 906 016 AJ
Component: R4 1,9L EDC 000SG 9961
Revision: --H06--- Serial number: VWZ7Z0H0010400
Coding: 0100031
Shop #: WSC 02736 790 00000
VCID: 5CB7F1759C33E4A288-5140
2 Faults Found:
001619 - Sensor Reference Voltage B
P0653 - 000 - Too High - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 8
Reset counter: 255
Mileage: 378668 km
Time Indication: 0
Freeze Frame:
RPM: 714 /min
Speed: 0.0 km/h
Bin. Bits: 00100000
Bin. Bits: 00100000
Bin. Bits: 00100000
Bin. Bits: 00100000
Bin. Bits: 00100000
000802 - Engine Speed Sensor (G28)
P0322 - 000 - No Signal - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 1
Fault Frequency: 2
Reset counter: 255
Mileage: 378668 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.08 V
Bin. Bits: 00000000
Idle Stabilization: 0.0°KW
RPM: 0 /min
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 7H0-907-37x-ESP.lbl
Part No SW: 7H0 907 379 R HW: 7H0 907 379 R
Component: ESP MK25E1 0104
Revision: 00H31001
Coding: 0001582
VCID: 448729150483BC62D0-5124
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 378668 km
Time Indication: 0
Freeze Frame:
Count: 128
Count: 13057
Count: 8196
Count: 1
Address 09: Cent. Elect. Labels: 7H0-937-049.lbl
Part No: 7H0 937 049 AE
Component: BORDNETZ SGVER 1.0 2101
Coding: 0000100
Shop #: WSC 00648 210 88441
VCID: 75E184D11FD955EA97-5106
No fault code found.
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 A
Component: 3C AIRBAG VW51 0011
Coding: 13123
Shop #: WSC 02736
VCID: 224B8F8DAED7925282-5124
Address 17: Instruments Labels: 7Hx-920-xxx-17.lbl
Part No: 7H0 920 951 T
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 00413
Shop #: WSC 00347
VCID: 3D715CF13769CDAA9F-5124
WV1ZZZ7HZ9H034508 VWZ7Z0H0010400
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 02736
VCID: 70EFB5C530BB70C244-5124
Address 46: Central Conv. Labels: 7H0-959-433.lbl
Part No: 7H0 959 433 B
Component: C1W Komfortgerát 0004
Coding: 00020
Shop #: WSC 02736
VCID: 326B7FCDFE3702D272-4B00
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 7H0 035 152 H HW: 7H0 035 152 H
Component: Radio LG3 0014
Revision: 00008000 Serial number: VWZCZ5H0027395
Coding: 0010200
VCID: 275D9E9995F5777AD5-5124
End-------------------------(Elapsed Time: 06:45)--------------------------
57 6E 76 77 78 7D
Coding: 0100031
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 255
Mileage: 378668 km
Time Indication: 0
Freeze Frame:
RPM: 714 /min
Speed: 0.0 km/h
Bin. Bits: 00100000
Bin. Bits: 00100000
Bin. Bits: 00100000
Bin. Bits: 00100000
Bin. Bits: 00100000
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 255
Mileage: 378668 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.08 V
Bin. Bits: 00000000
RPM: 0 /min
Revision: 00H31001
Coding: 0001582
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 378668 km
Time Indication: 0
Freeze Frame:
Count: 128
Count: 13057
Count: 8196
Count: 1
Coding: 0000100
Coding: 13123
Shop #: WSC 02736
Coding: 00413
Shop #: WSC 00347
Coding: 00006
Shop #: WSC 02736
Coding: 00020
Shop #: WSC 02736
Coding: 0010200
