Hi All,
I'm trying to remove the front headliner on my Kombi which has a sunroof fitted. I have the headliner mostly released but I am struggling to remove the A pillar hand rails and to identify where the upper light cluster which has the sunroof dial is fixed. Can anyone help.
Thanks, Steve
On my Kombi (2006) there's only one handrail & that's on passenger side above the door not on A pillar. But maybe the fixing is same as yours - pull the handle down & see there's a plastic cover on each end- these can be lifted carefully with a fine blade, to reveal bolts.
For the roof light cluster, use blade to remove blank plastic plate furthest from windscreen, & behind are two fixing bolts. Lower the whole unit carefully - the sunroof & light cables will come down with it.
Good luck - it's a lot of faff removing the from headlining & even more getting in back looking right.
Hi Thanks for that. I managed to get the cover off and I managed to get it all out.
Cheers,
Steve
