Hi there
I'm having a problem with the passenger's side window & wing mirror electrics. I've done some investigation and wondered if anyone could point me in the right direction.
Drivers side
Window switch lit up (when van lights on)
Drivers side window goes up & down
Drivers side wing mirror tilts/pans and heater works
Passenger side
Window switch IS NOT lit up (when van lights on)
Drivers side window DOES NOT go up & down
Drivers side wing mirror DOES NOT tilt/pan and heater DOES NOT work
Central locking works in both doors
Speakers work in both doors.
I can't get the passenger window to go down by holding the unlock button down on the key fob.
When I put the passenger's window switch into the drivers switch housing, it lights up but does not work as a switch
When I put the driver's window switch into the drivers switch housing, it does not light up and neither does it work as a switch.
But then I'm not sure that the switches are interchangeable in this way anyway (the passenger housing has 3 wires and the drivers housing has 4 wires).
I searched around the forum, and it looks like my motor might be duff, but just wondered if someone could confirm this for me,
Clive
2005 T5 130 4Motion
